<< Click to Display Table of Contents >> Navigation: »No topics above this level« Task Triggers |
Use triggers to automatically start a task.
You can add triggers to a task in the Task editor on the "Triggers" tab. You can add multiple triggers to a task.
When any active trigger fires, the task will be started automatically.
