<< Click to Display Table of Contents >> Navigation: Task Triggers > Hot Keys |
Executes a task that should be started manually. You can set up a combination of hot keys, such as CTRL + ALT + F. For example, you could set up a combination of hot keys to start Internet Explorer from your keyboard every time you want to browse the Internet.
Tip
•The Tray Icon triggering event also allows you start processes manually.
Hot Keys
Place your cursor in the box and press the keys you want on the keyboard. For example, press the ALT key to see "Alt" appear in the box.
Already in use
You can check which combinations are already used in RoboTask in other tasks.
