<< Click to Display Table of Contents >> Navigation: Task Triggers > Tray Icon |
Executes a task when you double-click a specific icon in the system tray of the Windows Taskbar. This is useful when you want a specific action to start, such as checking e-mail.
Tip
•The Tray Icon triggering event also allows you start processes manually.
Icon
File Name
Enter the name and path of an .Exe or .Dll file to select an icon from. You can click the browse button to select a file.
Current Icon
Displays icons available from the file that you select in the File Name box.
Popup Menu Options
One can define the popup menu items for an icon on this tab. In this case the ordinal number (beginning from 1) of selected will be passed into a/the task as a parameter.
Items
The list of menu items. This list can be edited with buttons Add, Edit and Delete. Also it is possible to change the order of options using buttons Move Up and Move Down.
To select Default Menu Item use the button Set Default.
Pass Item Number as Parameter
Specify the name of parameter in which the number of menu item must to be passed. On double click on the icon, the default item number of menu will be passed.
If the menu is empty, the parameter is 0 always.
