Rename File
Rename File
Renames one or more specified files. Wildcards are allowed. For example, you can copy the files to another folder and automatically rename them using this action.
FilesRename
Files
Enter the files you want to rename. Use the Plus buttons to add files or folders to the list. To clear the list, click the X button.
Tip
You can also use wildcards in this option. Some examples of wildcards are the following:
C:\Text Files\*.txt - all the files with the .txt extension in the C:\Text Files folder.
C:\Doc Files\mydoc?.doc - mydoc1.doc, mydoc2.doc, mydocA.doc, and so forth.
{bakext} - file mask(s) from the {bakext} variable.
Rename To
Enter the name or partial name for the new filename. You can use a wildcard if you want to rename part of the filename.
Recurse to Subfolders
Renames the files in the subfolders of the current directory.
Copy/Move File
Delete File
Write Text File
Search for Files
Change Folder
Create Folder
Rename Folder
Remove Folder
Synchronize Folders
Wait for file
Sort Text
Unique File Name
File Attributes
File Date and Time
Empty Recycle Bin
Get File Metadata
Read Text File
Get File Hash
Merge files
Split file
Match File Mask
