Merge files
Merge files
This action allows you to assemble a single file from several files. In fact, this action is the reverse of Split File action.
FilesMerge
Source files
Specify a list of files to merge. One file name on each line. Note: the order of the files is important. The files will be merged exactly in the order you specify in the list. Variables are allowed.
File names can be written manually or selected using the file selection dialog.
Merge mode
File Processing Mode. Two modes are available:
As text
As binary
Destination file
Enter the name of the destination file.
Copy/Move File
Rename File
Delete File
Write Text File
Search for Files
Change Folder
Create Folder
Rename Folder
Remove Folder
Synchronize Folders
Wait for file
Sort Text
Unique File Name
File Attributes
File Date and Time
Empty Recycle Bin
Get File Metadata
Read Text File
Get File Hash
Split file
Match File Mask
