Get File Metadata
Get File Metadata
This action is designed to extract the system properties of any file. In Windows Explorer, you can see these properties if you call the context menu of the file and select Properties -> Details tab
Note that the composition of these properties (metadata) depends on the file type. And also the metadata names depend on the system language and the version of Windows™. That is, in different systems, the same property can have different names
FilesGetMetadata
File Name
Specify the file name. You can use variables. You can also select a file interactively
Metadata Properties
The list of necessary properties. The value of each metadata property will be stored in a separate variable for the next processing.
Show All Metadata
You can see all non-empty metadata properties if you specify file name explicitly.
Copy/Move File
Rename File
Delete File
Write Text File
Search for Files
Change Folder
Create Folder
Rename Folder
Remove Folder
Synchronize Folders
Wait for file
Sort Text
Unique File Name
File Attributes
File Date and Time
Empty Recycle Bin
Get File Metadata
Read Text File
Merge files
Split file
Match File Mask
