Write Text File
Write Text File
Creates a text file with the specified text. For example, you can write a text file listing which user is logged into a computer at a particular time.
FilesWriteText
Text File
Enter the name of the text file to save. You can click the browse button to select a file.
Text
Enter the text that you want saved in the file.
Text Encoding
The action can provide the following coding:
ANSI text
UTF-8 text
Unicode text
Without format prefix (BOM)
BOM – byte order mark. Generally speaking, UTF8 and UNICODE formats should have a certain prefix at the beginning of the file. This prefix clearly indicates the format in which the text is written. However, sometimes this prefix interferes with further text processing. You can disable the use of BOM when writing a text file.
If File Exists
Specify the action to take if a file already exists in the destination location.
Overwrite - replaces the destination file with the new file.
Append - append specified text at the end of existing text file.
Suppress Trailing End-Of-Line symbols
If you want to remove trailing EOL symbols switch on this checkbox.
Copy/Move File
Rename File
Delete File
Search for Files
Change Folder
Create Folder
Rename Folder
Remove Folder
Synchronize Folders
Wait for file
Sort Text
Unique File Name
File Attributes
File Date and Time
Empty Recycle Bin
Get File Metadata
Read Text File
Get File Hash
Merge files
Split file
Match File Mask
