Get File Hash
Get File Hash
A hash value is a unique value that corresponds to the content of a file. A hash can be considered as a file identifier regardless of its name. There are many algorithms for calculating the hash of a file. This action allows you to use the most popular algorithms for calculating the hash.
FilesGetHash
File name
Enter or select file name.
Hash algorithm
Choose the algorithm. The are:
CRC32
MD5
SHA1
SHA256
SHA512
Save result to variable
Enter the name of the variable in which you want to store the value. Hash value is an alphanumeric string
For example: 892B0DF594808BF7F6B2C585F8C00775
Copy/Move File
Rename File
Delete File
Write Text File
Search for Files
Change Folder
Create Folder
Rename Folder
Remove Folder
Synchronize Folders
Wait for file
Sort Text
Unique File Name
File Attributes
File Date and Time
Empty Recycle Bin
Get File Metadata
Read Text File
Merge files
Split file
Match File Mask
