Synchronize Folders
Synchronize Folders
Synchronizes the two folders that you specify. The synchronization method may be bi-directional or uni-directional. For example, if you travel a lot, you might want to create a task that synchronizes data in a folder on your laptop computer and a folder on your desktop computer.
FilesSync FilesSync2
General tab
Folder 1
Enter the first folder that you want to synchronize. You can click the browse button to select a folder.
Folder 2
Enter the second folder that you want to synchronize.
Swap Folders
Click to place the folder listed in Folder 2 in the Folder 1 box and the folder in Folder 1 in the Folder 2 box.
Include Masks (Comma Separated)
List masks that need to be included to the search separated by commas. For example: *.txt,*.doc,*.pdf
Tip
You can also use wildcards in this option. Some examples of wildcards are the following:
*.txt - all the files with the .txt extension.
mydoc?.doc - mydoc1.doc, mydoc2.doc, mydocA.doc, and so forth.
*.tmp, *.$$$, *.bak - all the files with the .tmp, .$$$ and .bak extensions.
{bakext} - file mask(s) from the {bakext} variable.
Exclude Masks
Enter one or more masks separated with commas to specify which files to skip in the synchronization. You can specify one or more masks separated by commas; for example, *.bak, *.old, *.$$$.
If you are using the search mode with nested folders, you can exclude individual folders from the search. To do this, specify the mask along with the path.
For example:
 C:\incoming\files\*.*
This means that all files starting from the folder "c:\incoming\files" will be excluded from the search.
How to Synchronize
Select one of the following options:
Folder 1 <=> Folder 2 (Bi-directional) - new or newer files that are available in Folder 1 are copied to Folder 1, and vice versa.
Folder 1 ==> Folder 2 (Uni-directional) - only new or newer files that are available in the Folder 1 are copied to Folder 2; the contents of Folder 2 does not affect the contents of Folder 1.
Include Subfolders
Click this check box to synchronize all files in the subfolders.
Exact Copy in Folder 2
Available only with unidirectional synchronization when you select Folder 1 ==> Folder 2. This option ensures that files that are available in Folder 2, but not in Folder 1, are deleted.
Sync an Empty Folders
If this checkbox is switched on, the action copies the structure of empty folders. Otherwise, only files will be synchronized.
Advanced options
Output Activity to Log
If you want to write the log of synchronization into the task log, switch on this checkbox. The action will put the information about coped and removed files into the task log.
Output Activity to variable
If you want to write the log of synchronization into a variable, switch on this checkbox and put the variable name in the field. The action will put the information about coped and removed files into the log.
Two seconds precision
Two seconds precision is useful when copying files between different file systems. For example: FAT32 and exFAT do not save milliseconds and rounds the file time with 2 seconds accuracy. But NTFS saves the file time with millisecond accuracy.
Thus, the date and time of the same file will never be exactly equal on different file systems.
Check if the file is free before copying
If you want to ensure that the file is not open in another application, check this checkbox and specify the required timeout for waiting. If the file is not released within the specified timeout, the action will issue a warning "Can't copy file" and skip copying this file.
Copy/Move File
Rename File
Delete File
Write Text File
Search for Files
Change Folder
Create Folder
Rename Folder
Remove Folder
Wait for file
Sort Text
Unique File Name
File Attributes
File Date and Time
Empty Recycle Bin
Get File Metadata
Read Text File
Get File Hash
Merge files
Split file
Match File Mask
