Delete File
Delete File
Deletes one or more files you specify. Wildcards are allowed. For example, you can use this action to automatically delete cookies from your Internet cache every day to protect your privacy and computer security.
FilesDelete
Files
Enter the files you want to delete. Use the Plus buttons to add files or folders to the list. To clear the list, click the X button.
Tip
You can also use wildcards in this option. Some examples of wildcards are the following:
C:\Text Files\*.txt - all the files with the .txt extension in the C:\Text Files folder.
C:\Doc Files\mydoc?.doc - mydoc1.doc, mydoc2.doc, mydocA.doc, and so forth.
{bakext} - file mask(s) from the {bakext} variable.
Delete to Recycle Bin
Moves files to the Windows Recycle Bin. Use this flag to prevent possible data loss.
Recurse to subfolders
Deletes the files in the subfolders of the current directory.
Delete Folders
Removes the subfolders. This option works only with wildcards.
Copy/Move File
Rename File
Write Text File
Search for Files
Change Folder
Create Folder
Rename Folder
Remove Folder
Synchronize Folders
Wait for file
Sort Text
Unique File Name
File Attributes
File Date and Time
Empty Recycle Bin
Get File Metadata
Read Text File
Get File Hash
Merge files
Split file
Match File Mask
