<< Click to Display Table of Contents >> Navigation: Actions > Email > IMAP Set Message Flags |
Sets up message flags according to the number in the current folder. Flags are set by means of checkboxes. Notice that each checkbox has 3 statuses:
•Off. This means that the flag should be resetted (cleared).
•On. This means that the flag should be set.
•Intermediate status. This means that the flag should be left unchanged.
Message Number
The ordinal number of the message in the current server folder.
Message Flags
Set up new message flags by means of checkboxes. There are 6 checkboxes which correspond to the message flags:
•Answered
•Flagged
•Deleted
•Seen
•Draft
•Recent
Notice, that to mark the message for deletion, it is enough to mark it with the flag Deleted. After all necessary messages are marked, the action IMAP Delete Marked Messages needs to be performed.
