<< Click to Display Table of Contents >> Navigation: Actions > Email > IMAP Select Mail Folder |
The action is designed for changing of the current folder of the mail server during execution of a task.
Select Mail Folder
Specify the name of a folder of the IMAP server. The folder name can be typed manually explicitly or using variables. Also the folder name can be selected from the list pressing the button on the right of entry field.
