<< Click to Display Table of Contents >> Navigation: Actions > Email > IMAP Folder Info |
The action enables to read parameters of the current folder and to save their values into variables for the next processing.
The folder parameters which can be extract:
•The folder name
•Amount of messages
•Amount of not shown messages
•Amount of resent messages
To extract the parameter value, it is necessary to switch on the appropriate checkbox and to input the variable name.
