<< Click to Display Table of Contents >> Navigation: Actions > Email > IMAP Copy Message |
The action performs copying of a message from the current folder into other folder of the server.
Message Number
The number of a message in the current folder. The numbers begin from 1. It is allowed to use variables.
Copy Message to this Folder
Input the name of the destination folder. The folder name can be input manually or selected from the list pushing the selection button on the right of the field. Also it is allowed to use variables.
Note:
If you want to MOVE the message into another folder you have to copy the message and then mark it as DELETED (see IMAP Set Message Flags action). Also you can put the IMAP Delete Marked Messages after moving all necessary messages.
