<< Click to Display Table of Contents >> Navigation: Actions > CSV Data > CSV Read Cells |
This action reads CSV data fields and saves them into the specified variables.
General
Cells list
This is a list of fields in the data array that need to be read, specified by their coordinates (row, column). For each cell, you should indicate the variable in which the read value should be stored. The row and column numbers start from 1.
Source and Source format
