CSV Sort by Column
CSV Sort by Column
This action sorts the CSV data based on the specified column.
General
CSVSortByColumn1
Sort by column
Specify the column number to sort the data by.
Sort direction
Select the sorting direction: ascending or descending.
Sort Mode
Comparison mode for sorting: as strings or as numbers.
Case Sensitive
Enable this toggle if you want to compare strings in a case-sensitive manner.
Source and Source format
CSV Open Data
CSV Get Data Information
CSV Add Column
CSV Add Row
CSV Remove Column
CSV Sort by Column
CSV Move Column
CSV Read Cells
CSV Write Cells
CSV Merge Data
CSV Filter Data
CSV Data Loop
CSV Remove Duplicates
CSV Save Data
SQL Query to CSV File
Read system events to CSV
Load process info to CSV
