CSV Add Column
CSV Add Column
This action adds a column to the CSV data.
General
CSVAddColumn1
Action
Column addition mode:
Append column - add the column at the end.
Insert column - insert the column at the specified position. Note that the column numbering starts from 1. If the specified position is less than 1 or greater than the number of columns, the column will be added at the end.
Column name
Enter the name of the new column.
Fill mode
Fill mode for the new column. Three options are available:
Empty value
Sequence number - the action fills the field with the row number, starting from 1.
Static value - the action fills all entries of the new field with the specified value.
Source and Source format
CSV Open Data
CSV Get Data Information
CSV Add Column
CSV Add Row
CSV Remove Column
CSV Sort by Column
CSV Move Column
CSV Read Cells
CSV Write Cells
CSV Merge Data
CSV Filter Data
CSV Data Loop
CSV Remove Duplicates
CSV Save Data
SQL Query to CSV File
Read system events to CSV
Load process info to CSV
