<< Click to Display Table of Contents >> Navigation: Actions > CSV Data > CSV Add Row |
This action adds a new row to the CSV data.
The row is always appended to the end of the current CSV data. Inserting a row at a specified position is not supported.
General
Row mode
Select how to fill the new row:
•Empty Data - add an empty row. The number of cells is adjusted to the current CSV data structure.
•Specified string - add a row from the specified CSV string.
Source and Source format
