CSV Write Cells
CSV Write Cells
This action allows you to write new values to CSV data fields.
General
CSVWriteCells1
Cells list
This is a list of fields in which new values should be written, specified by their coordinates (row, column). For each cell, you should indicate the value to be written. The row and column numbers start from 1.
Source and Source format
CSV Open Data
CSV Get Data Information
CSV Add Column
CSV Add Row
CSV Remove Column
CSV Sort by Column
CSV Move Column
CSV Read Cells
CSV Write Cells
CSV Merge Data
CSV Filter Data
CSV Data Loop
CSV Remove Duplicates
CSV Save Data
SQL Query to CSV File
Read system events to CSV
Load process info to CSV
