CSV Data
Navigation:  Actions >
CSV Data
This group contains actions for working with CSV texts. CSV data (comma-separated values) is a popular format for data exchange between different systems. However, manual processing of this data can be challenging because CSV data is simply text. Generally, to perform any actions with this data, you need to load it into a database or Excel. These actions will help you avoid that.
To manipulate the data, you need to first open the data. Use the "CSV Open Data" action. Additionally, almost every action allows you to independently load data from a file or variable.
All actions are designed in such a way that opened CSV data is stored in memory until the task is completed.
Note that the data is not automatically exported to a file or variable. To save the data, you must use the "CSV Save Data" action.
CSV Open Data
CSV Get Data Information
CSV Add Column
CSV Add Row
CSV Remove Column
CSV Sort by Column
CSV Move Column
CSV Read Cells
CSV Write Cells
CSV Merge Data
CSV Filter Data
CSV Data Loop
CSV Remove Duplicates
CSV Save Data
SQL Query to CSV File
Read system events to CSV
Load process info to CSV
