CSV Move Column
CSV Move Column
This action moves a column to a new position.
General
CSVMoveColumn1
Column number
Specify the column number to be moved. Column numbers start from 1.
Move to
Specify the new position for the column.
Source and Source format
CSV Open Data
CSV Get Data Information
CSV Add Column
CSV Add Row
CSV Remove Column
CSV Sort by Column
CSV Move Column
CSV Read Cells
CSV Write Cells
CSV Merge Data
CSV Filter Data
CSV Data Loop
CSV Remove Duplicates
CSV Save Data
SQL Query to CSV File
Read system events to CSV
Load process info to CSV
