CSV Save Data
CSV Save Data
This action saves CSV text to a variable or file.
Note that CSV data array is not automatically saved to a file or variable.
General
CSVSaveData1
Save to variable
Turn this switch on and specify the variable name to save the CSV text.
Save to file
Turn this switch on and specify the file name to save the CSV text. Also, specify the text encoding if needed.
Note that UTF-8 is a universal format for any language.
Keep original format
By default, the action suggests keeping the CSV text formatting (delimiter, quotes, etc.). But you can choose a different format. Simply turn this switch off and specify the new format on the CSV Format tab.
CSV format
CSVSaveData2
Specify the format of the CSV data: delimiter, quote character.
Note that if the "Strict delimiter" switch is not enabled, spaces are also considered delimiters. And all fields containing spaces must be enclosed in quotes.
Reset to standard format
Sets the standard parameters:
Delimiter: Comma (,)
Quotes: Double quotes (")
Non-strict delimiter (spaces are also considered delimiters)
Reset to Excel format
Sets the parameters used by MS Excel by default:
Delimiter: Semicolon (;)
Strict delimiter.
CSV Open Data
CSV Get Data Information
CSV Add Column
CSV Add Row
CSV Remove Column
CSV Sort by Column
CSV Move Column
CSV Read Cells
CSV Write Cells
CSV Merge Data
CSV Filter Data
CSV Data Loop
CSV Remove Duplicates
CSV Save Data
SQL Query to CSV File
Read system events to CSV
Load process info to CSV
