<< Click to Display Table of Contents >> Navigation: Actions > CSV Data > CSV Remove Column/Record |
This action removes the specified column by numbers. Column numbers should be listed separated by commas. If a column number is less than 1 or greater than the number of columns, the action logs a warning in the task log. If it is not possible to remove any column, the action generates an error.
General
Remove columns
One or more column numbers
List the column numbers to be removed, separated by commas. Column numbers start from 1 and should not exceed the total number of columns.
Remove rows
One or more rows numbers
List the rows numbers to be removed, separated by commas. Row numbers start from 1 and should not exceed the total number of rows.
Source and Source format
