CSV Filter Data
CSV Filter Data
This action allows you to filter CSV data records based on specified conditions. All records that do not meet your criteria will be deleted. This can be useful to reduce data for further processing if needed.
General
CSVFilterData1
Delete rows that...
Record deletion mode:
•        ...don't match filters - keep only the records that meet your conditions. The remaining records will be deleted.
•        ...match filters - delete all records that meet your conditions.
Filter options
Filter mode:
Choose the condition combination mode: AND (all listed conditions must be met) or OR (at least one condition must be met).
Filter list
Col - Each condition corresponds to a specific column.
Kind - Filter Type. Four options are possible:
substring - the column must contain the specified value
regexp - the column must match the specified regular expression. Regular expressions are more flexible for defining conditions but require some skills.
as number - column value should be interpreted as a number. In addition, a comparison operator with the specified value must be selected.
as datetime - column value should be interpreted as a number. In addition, a comparison operator with the specified value must be selected.
Value - value to which the column value is to be compared. Date and time must be specified in the current system format.
Extras - additional notes to filter: case sensitive, date-time format
Source and Source format
CSV Open Data
CSV Get Data Information
CSV Add Column
CSV Add Row
CSV Remove Column
CSV Sort by Column
CSV Move Column
CSV Read Cells
CSV Write Cells
CSV Merge Data
CSV Filter Data
CSV Data Loop
CSV Remove Duplicates
CSV Save Data
SQL Query to CSV File
Read system events to CSV
Load process info to CSV
