CSV Data Loop
CSV Data Loop
This action iterates through CSV data records in the loop, considering specified conditions.
General
CSVDataLoop1
Save row number to variable
Specify the variable name to store the row number. Row numbers start from 1. This field can be left empty.
Save current row to variable
Specify the variable name to store the current record. This field can be left empty.
If you want to save the current record for processing, specify the format:
Standard comma-separated string (default format)
JSON array
Filter options
Filter mode:
Choose the condition combination mode: AND (all listed conditions must be met) or OR (at least one condition must be met).
Filter list
Col - Each condition corresponds to a specific column.
Kind - Filter Type. Four options are possible:
substring - the column must contain the specified value
regexp - the column must match the specified regular expression. Regular expressions are more flexible for defining conditions but require some skills.
as number - column value should be interpreted as a number. In addition, a comparison operator with the specified value must be selected.
as datetime - column value should be interpreted as a number. In addition, a comparison operator with the specified value must be selected.
Value - value to which the column value is to be compared. Date and time must be specified in the current system format.
Extras - additional notes to filter: case sensitive, date-time format
Source and Source format
CSV Open Data
CSV Get Data Information
CSV Add Column
CSV Add Row
CSV Remove Column
CSV Sort by Column
CSV Move Column
CSV Read Cells
CSV Write Cells
CSV Merge Data
CSV Filter Data
CSV Data Loop
CSV Remove Duplicates
CSV Save Data
SQL Query to CSV File
Read system events to CSV
Load process info to CSV
