Add Folder for Watch Dialog Box
Folder Name
Enter the name of the folder that you want the task to monitor. Click the browse button to select folders on the local or remote computer.
Watch Subfolders
Click the check box to ensure the task monitors subfolders of the folder that you selected in the Folder Name box.
