<< Click to Display Table of Contents >> Navigation: Actions > SSL FTP > SSL FTP Upload |
Allows you to place files on an Ftp site. For example, if you must post daily updated financial reports to a web site, you can create a task to automatically upload the updated reports to the company web site at the end of each day.
Tip
•Click the {V} button to insert a variable that holds the name of the local file or the remote folder.
Local File
Enter the name of the local file that you want to copy to the remote server.
Remote Folder
Enter the path and name of the directory on the remote server.
If destination file exists
•Overwrite - the action will overwrite the file completely
•Rename - the action adds a sequence number to the file name and creates a file with a new name.
•Append - the action appends the contents of the source file to the end of the destination file
