<< Click to Display Table of Contents >> Navigation: Actions > SSL FTP > SSL FTP Rename File |
Allows you to change the name of files on a remote server. For example, in an FTP session, you can use this action to rename files that you might accidentally overwrite on the remote server with updated files.
Tip
•Click the {V} button to insert a variable that holds the new file name or the old file name.
Old File Name
Enter the name of the file that you want to rename.
New File Name
Enter the name that you want to give the file.
