<< Click to Display Table of Contents >> Navigation: Actions > SSL FTP > SSL FTP Download |
Copies remote files to the local computer using the current file transfer type. For example, if you are participating in a software beta program, you can download daily updates automatically to stay up-to-date.
Tip
•Click the {V} button to insert a variable that holds the name of the local file or the remote folder.
Remote File
Enter the name of the remote file that you want to copy to the local computer.
Local Folder
Enter the path and name of the local directory to which you want to copy the remote file.
