<< Click to Display Table of Contents >> Navigation: Actions > SSL FTP > SSL FTP Remove Folder |
Allows you to delete a folder on a remote server. For example, you can create a task to remove company reports that are more than six months old from the remote server.
Remote Folder
Enter the path or folder name on the remote server that you want to remove. Click the {V} button to insert a variable that holds the name of the folder.
