<< Click to Display Table of Contents >> Navigation: Actions > SSL FTP > SSL FTP Create Folder |
Allows you to create a new folder on a remote server. For example, during an FTP task, you can use this action to create a new folder based on the current date for each set of daily backup files.
Remote Folder
Enter the path or folder name on the remote server that you want to create. Click the {V} button to insert a variable that holds the name of the folder.
