<< Click to Display Table of Contents >> Navigation: Actions > SSL FTP > SSL FTP Log Off |
Allows you to log off an Ftp site, or remote server. No specific settings are associated with this action. For example, when you work from home, you can create a task that Ftps daily files that you have worked on to a remote server in your company's network to protect your data.
