<< Click to Display Table of Contents >> Navigation: Actions > SSL FTP > SSL FTP Delete File |
Allows you to remove files from a remote server. For example, you can use this action to remove old backup files on the remote server that are no longer needed.
Remote File
Enter the path and file name that you want to delete on the remote server. Click the {V} button to insert a variable that holds the path and name of the file.
