<< Click to Display Table of Contents >> Navigation: Actions > Strings > TXT Delete line |
The action allows to remove one line from the text by line number.
Text from external file
Enter file name or select file from dialog. You can use variables.
Use this text
Enter the text into this field. You can use variables in the text
Line number
Enter the number of the line to be removed from the text. The line number starts at 1. If the line is less than 1 or greater than the number of lines, then the action writes a warning to the task log.
Assign result to variable
Enter variable name where you want to save the result.
