<< Click to Display Table of Contents >> Navigation: Menus > Task > Task - Import |
Import of a task from a text file to the repository of RoboTask. When you import you will be proposed to select the task file (or several files). The tasks will be imported to the active selected task folder.
Also you can import tasks by using drag-and-drop mechanism
Note: Pay attention that the imported tasks are always disabled after importing. You have to enable it manually.
Task - Create Shortcut on Desktop
