<< Click to Display Table of Contents >> Navigation: Menus > Task > Task - Local running task |
This is the service of a search of the task running at the moment. You will see only running at the moment tasks in the list of the dialog window.
To go to the task highlight the searched task and press the button OK or use the Double-Click on the searched task.
Task - Create Shortcut on Desktop
