Task - Edit
Navigation:  Menus > Task >
Task - Edit
Allows you to edit a task. After you select the command, the Edit Task dialog box displays, allowing you to select the following items to edit the task:
Actions tab
Triggers tab
Settings tab
Variables tab
Notes tab
The task editor is described in the previous chapter.
Task - New
Task - Delete
Task - Run
Task - Stop
Task - Find the task
Task - Local running task
Task - Export
Task - Import
Task - Copy
Task - Paste
Task - Duplicate
Task - Create Shortcut on Desktop
Task - Create Batch File
Task - Exit
Debugging of the task
