<< Click to Display Table of Contents >> Navigation: Menus > Task > Task - Export |
Export of a task to an external file. You can also export several tasks. To export tasks highlight the task (or several tasks) in the list and select this menu item. RoboTask will export the tasks into a text file.
Also you can export task by using drag-and-drop mechanism
Task - Create Shortcut on Desktop
