<< Click to Display Table of Contents >> Navigation: Menus > Task > Task - Create Batch File |
Create a batch file to run a separate task from a command line. To create a batch file highlight the task in a list and select this menu item. After that the program will propose to select a folder and a file name.
Task - Create Shortcut on Desktop
