<< Click to Display Table of Contents >> Navigation: Menus > Task > Task - Find the task |
This is the service of a quick search of a task by the task name. You can see a dialog with a complete task list. Just begin typing a search string. The dialog will be filtering the task list when typing the string. Only the tasks containing the typed string in their name will be present in the list.
To go to the task, highlight the searched task and press the button OK. You also can jump to the task using the Double-Click on the searched task.
Task - Create Shortcut on Desktop
