<< Click to Display Table of Contents >> Navigation: Menus > Task > Task - Paste |
If in the system clipboard is the copied task (or several tasks), you can paste them in an active task folder pressing Ctrl-V or selecting this item of the main or context menu.
The method of copying of tasks by means of the clipboard works with remote tasks too if the network connection with remote RoboTask is open. That is you can copy a local task and paste it in a remote session and vice versa.
Note: Pay attention that the pasted tasks are always disabled after the operation. You have to enable it manually.
Task - Create Shortcut on Desktop
