<< Click to Display Table of Contents >> Navigation: Menus > Task > Task - Copy |
You can copy a task by means of the method Copy-Paste using the system clipboard. Just highlight one or several tasks in a list and press Ctrl-C (or select this item of the main or context menu).
Task - Create Shortcut on Desktop
