<< Click to Display Table of Contents >> Navigation: Several practical recommendations > Drag and Drop |
With the drag-and-drop mechanism, you can not only move tasks between task folders, but also easily export tasks to a file or email message as an attachment. You can also import tasks into RoboTask from a file or email message.
Export using drag-and-drop:
Select one or more tasks from the task list, press the SHIFT key and drag the selected tasks to an open Windows Explorer window or email message editor.
Import using drag-and-drop:
Simply drag the task from the Windows Explorer or email client message window to the RoboTask window. It is not necessary for the file to have a TSK extension. RoboTask will analyze the contents of the file itself. If the file does not contain a task, RoboTask will ignore the "dropped" file.
