<< Click to Display Table of Contents >> Navigation: Actions > Graphics > Save Image |
This action saves the current image to file or system clipboard.
Destination
Choose the file save destination:
•File
•Clipboard
Image File
Enter the file name if you choose to save to file.
Image Format
When saving to file, choose the file format. When saving to clipboard, this parameter is omitted.
Save Metadata if available.
Select this checkbox if you need to save metadata (additional image info). Metadata (if any) are loaded when the image is opened. Please note that an image in clipboard cannot contain metadata.
If file already exists
The action if file already exists.
