Crop Image
Navigation:  Actions > Graphics >
Crop Image
This action crops the image according to the parameters specified.
ImageCrop
Left, Top, Right, Bottom
Crop boundaries. The boundaries can be specified in both pixels and percentage points.
If a positive number is specified, it represents the absolute coordinates of the crop boundaries.
If a negative number is specified, this means a space from the relevant width or height of the image.
For example if you want to cut off 10 pixels from each side you have to specify such parameters:
Left   =  10px
Top    =  10px
Right  = -10px
Bottom = -10px
The use of variables is allowed.
Open Image
Save Image
Resize Image
Rotate Image
Draw Text on Image
Draw Image on Image
Add Border to Image
Generate QR Code
Scan QR/Bar Code
