<< Click to Display Table of Contents >> Navigation: Actions > Remote Task > Stop Remote Task |
Stops the specified task.
Select task by ...
You can specify a task in two ways:
•by External Name - this method is preferable because you can define the External Name yourself to identify the task (see Task Editor -> Settings)
•by Task ID - if you know the ID, you can specify the task ID directly. Task ID is a formal unique number. It is assigned once when creating or importing a task and does not change during the "life" of the task.
Task External name or Task ID
The title of this field changes depending on the value of the task selection mode. Specify the External Name or TaskID, respectively. Variables can be used.
Select task from list
External Name or TaskID can be selected interactively from the list. To do this, the first time you need to enter the parameters for connecting to the remote RoboTask to get the list. The connection parameters are saved for the next sessions.
Kill the task if it doesn't stop within ...
You can force abort the task if needed. Turn this switch on and specify the desired timeout in seconds.
