<< Click to Display Table of Contents >> Navigation: Actions > Remote Task |
This set of actions is used to manage tasks in the remote RoboTask. A remote RoboTask instance can run on another computer, in another session, or in service mode.
Before you start working with remote tasks downloaded, you need to connect to a remote instance of RoboTask using the Remote Task Connect action. One RoboTask can only support one connection.
