Enable/Disable Remote Task
Navigation:  Actions > Remote Task >
Changes the Enabled property of a task on a remote RoboTask instance.
RemoteTaskEnable
Select task by ...
You can specify a task in two ways:
by External Name - this method is preferable because you can define the External Name yourself to identify the task (see Task Editor -> Settings)
by Task ID - if you know the ID, you can specify the task ID directly. Task ID is a formal unique number. It is assigned once when creating or importing a task and does not change during the "life" of the task.
Task External name or Task ID
The title of this field changes depending on the value of the task selection mode. Specify the External Name or TaskID, respectively. Variables can be used.
Select task from list
External Name or TaskID can be selected interactively from the list. To do this, the first time you need to enter the parameters for connecting to the remote RoboTask to get the list. The connection parameters are saved for the next sessions.
Action
There are two options to choose from
Enable - "enables" the task. In other words, it starts all connected task triggers.
Disable - stops all task triggers. In this case, the task will not start automatically.
Remote Task Connect
Remote Task Disconnect
Start Remote Task
Stop Remote Task
Wait for Remote Task
Remote Task Status
Active Connections Loop
