Remote RoboTask Disconnect
Navigation:  Actions > Remote Task >
The action closes the current connection to the remote RoboTask.
The action does not require additional parameters.
Remote Task Connect
Enable/Disable Remote Task
Start Remote Task
Stop Remote Task
Wait for Remote Task
Remote Task Status
Active Connections Loop
