Input Date and Time
Input Date and Time
This dialog box is designed for entering the date and time by selecting the date in the calendar and the time using a special time input element. This allows you to enter the date and time without errors in accordance with your system settings.
Of course, you can enter the date and time in your system format using the Input Box dialog. However, this method does not rule out the possibility of errors in the entered string. It is up to the user to choose which type of dialog to use.
DialogInputDateTime
Title
Dialog title. The editor suggests a default value. If necessary, the title can be changed to any other value.
Initial date
Initial date value
Initial time
Initial time value
Save the result in variable
Enter the name of the variable in which you want to save the entered value.
If "Cancel" pressed
Action if the Cancel button is pressed:
Stop task
Save the specified value in a variable. The default value is “NONE”.
Test
Test the dialog.
note Related topics
Show Message/Play Sound
Question Dialog
Open Dialog
Save Dialog
Browse for Folders
Browse for Computers
Input Box
Input Date and Time
Desktop Alert
Choice Dialog
Multichoice Dialog
Show Text
Custom Input Dialog
Log Dialog
